siemens LOGO! 230rl pinouts
Salam,
don't trouble your self finnaly I made teh right siemens logo cable.
it's 100% working
I attached the original one and teh homemade one
enjoy programming!
Hello! Is this circuit working, somebody tested it? It is working without optocouplers?
I would appreciante an answer. Thank you!
Logo programming cable pin out,
From a LOGO! 24R a 230 should be the same.
Adapter I made works fine, No DONGGLE is used...
LOGO unit is upright:
starting upper left pin as #1 (not labelled using convention)opposite side is #6, key is on right side of connector.
1-TTL in Rx Serial
2-Gnd
3-5 volts
4-SDA for card
5-SCL for card
6-TTL out Tx Serial
You will need TTL<->RS232 converter (ie MAX202) powered by pin 3 of LOGO.
Baud rate is 9600, 8bit, even HEX char.
ed
from this post, this are the pinouts for the end LOGO connector.
I bought a logo 12/24RC and the schematic do work!! regarding to connector, I just solder strong wires (thin enough) to small pcb. Thanks community.
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
287
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,077
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,045
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,409
Hi, I'm no expert in PID regulating so I need some advise. I have a VFD controlled deepwaterpump that is maintaining the pressure in a closed...
24
11,909
