I include a simple program, where an an analogue input switches on Pump 1 and if needed a higher analogue level switches on pump 2.
Works fine, but am curious, if I wanted to alternate the two pumps, what's the best way to do it ?
i.e if the sump level fill is slow then pump 1 would always run and wear out, so alternating the low/high pump would keep both pumps running equal time.
