siemens logo pulse time
walters
Feb 2005
reusel
185
we want to control solid state relays and switch them on and of using a PLC.
the PLc we had in mind for this aplication is a siemens logo.
now we wore searching for the minimum time between 2 pulses but cant find it anywhere.
is there someone who can tell me how long that time is??
regards walters
Hello Walters;
Here is some of the available info for the LOGO! output swtich times:
This is taken from the Logo_e.pdf, downloable from the Siemens support website.
By the way, many do not consider the LOGO! (and its siblings like the Easy) as a PLC; it is a programmable relay. It does what it does very well, but it has no data manipulation/storage or communications available, which limits its use in control applications.
Hope this helps,
Daniel Chartier
Edit:
Ron, we seem to be on the same wavelength; you're just a little bit faster...
okay okay sorry for calling the logo a PLC didn't know its such a sensitive spot but thx for the info.
i appreciate youre help
regards walters
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
308
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,087
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,055
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,421
Hi, I'm no expert in PID regulating so I need some advise. I have a VFD controlled deepwaterpump that is maintaining the pressure in a closed...
24
11,942
