Siemens LOGO!Soft V8 Help
minibarrow
Feb 2020
Durrington
Hello All,
I am using Siemens LOGO!Soft V8 to write a program and am unsure of where the function is fo the CTU as seen in the attached picture.
I am doing the dreaded BATCH MIXER PLC and everyone seems to do this using the LogixPro, but I am required to cay out this in LOGO!Soft.
Also what would I use to replicate a flow meter...would this be the pulse generator function?
All help and assitance would be much appeciated.
Welcome,
This is an Allen Bradley RSLogix counter, there is an equivilent in the LOGO but it will look nothing like the RSlogix counter, you need to use the count up/down counter function then double click it to set up. It is self explanitory how to use it, however I would obtain and read the manual.
Steve
I am doing a PLC Program for a course and am looking for a function to act as a pulse generator for a flow meter and a counter that will count these pulses to 10 then reset to 1 as a high/low sensor.
Please see below fo better understanding:
Use LOGO to design and build the above system, using function block or ladder logic, which will control the operation as follows:
The pulses generated by flow meter 1 (B5: pulse generator) should be used to increment the counter (B6: Up/down). Tank level full is when the counter function on = 10 and tank low level is when counter off = 1. These values can be used as feedback to control the pumps (instead of the high/low level sensors shown above) and can be called the ‘tank high/low level count indicator’
I am really struggling to get a LOGO PLC to communicate with indusoft web studio 7.1. I am trying to use then SIETH driver. I cannot get the...
2,376
Hi there, I am a new PLC user. I am now using LOGO! Soft Comfort Demo version and trying to transfer program from PC to LOGO! 230RC thro' PC...
5,179
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
287
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,077
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,042
