Siemens Logo + TD
Nathan_9999
Oct 2010
Hartlepool
Hello all
Im about to fit a Logo + Logo TD, it takes in a 4-Bit BCD input, in which i chooses certain timers to give pressure setting, depending what setting is set at that time the screen changes to present the relative infomation to the operators, I have fitted TD's before and used them for counting, i noticed that on the TD, the count values set points can be chaged easily, im not sure if this is the same for timers, but is there a way that i can stop people from changing these Counter/Timer set points from the TD Panel itself. Locking that page out some how???
Hi Nathan, welcome to the forum
open your logo program and double click on the timer you don,t want peole to change, the parameter box opens up for it, set protection active !! that should stop the value being changed on the TD.
Regards
John V
Thanks john, i think i need my eyes checking for missing that. but i also meant is there away so that the operator cant go to any of the set up screens, i did a thing before where you had to Hold F1 & F4 down for 4 seconds to reset counts, is there away of doing this so i can get to another screen, where timer value can be changed, becuase although i dont want the operator to be able to change anything i would still like access to them through the TD??
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
313
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,088
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,058
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,424
Hi, I'm no expert in PID regulating so I need some advise. I have a VFD controlled deepwaterpump that is maintaining the pressure in a closed...
24
11,944
