Siemens logo
peterp
Aug 2007
QLD
Hi All,
I am new to PLC's (ok, programmable relays)
I have a couple of questions in relation to the Logo.
Question 1: Does the siemens logo have similar functionality to the Mitsubishi AL2-10MR-D. I need to replace the Mitsubishi unit with a 12vdc product and the siemens came to mind.
Programming question:
I have 2 inputs (input-A and input-B) and also has 2 outputs (output-A and output-B) Depending on which order the input-A or input-B are triggered (within a defined period say 1-sec), will determine which output A or B generates a pulse. Can someone give me a hint on how to approach this task with the siemens logo.
TIA
Peter
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
297
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,082
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,048
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,415
Hi, I'm no expert in PID regulating so I need some advise. I have a VFD controlled deepwaterpump that is maintaining the pressure in a closed...
24
11,921
