Siemens MM440
Benton
Oct 2010
Baton Rouge
34
We have a mm440 drive that is not starting remotely in automatic. We can control the locally when in hand mode with 0-10v potentiometer. When we put the drive in auto the control room can start and stop it but cannot control the speed. Any suggestions?
I guess it is controlled remotely via Profibus ?
I suggest you get the STARTER software on a laptop and go online with the drive. You need a serial port and a serial adapter on the drive, I think it is called "PC connection kit" or something like that.
You can also go online on the drive via Profibus, but if you knew how to do that I guess you wouldnt ask on the forum.
You can also in theory just check parameters with the BOP panel if you know what to look for.
Going online with STARTER will give you a view of the setpoint channel. And you can see where it goes wrong.
Definitely get STARTER. It is free and the PC connection kit is inexpensive.
STARTER will show you a graphical flow sheet of the setpoint channel.
You can backup the settings to view offline, and to restore if they have become messed up.
And as there are 1000s of parameters it is a pain to go through them one by one with the little BOP.
Hey i have an old application that i have change this: torque limit P1520 5.20 P5121 -5.20 when I start the drive and it stuck i have R31 2.35...
4,209
Any help appreciated Micro master 440, one old, one brand new in box Starter kit loaded on xp sp3 in vmware machine USB-serial adapter -...
2,475
Hello, I'm currently working on a proyect where I'm using a MicroMaster440 (siemens variator) to controll a motor and I want to use the MM440 PID...
4,165
We wish to use Siemens MM440 in extrusion application, where motor works in torque control mode in one direction and speed control mode in reverse...
5,291
Dear All !! We are going to use Micromaster MM440 for puller application in Extrusion process. Problem is how to changeover...
3,361
