Siemens MP277 connection to Remote PC using DNS
agrade
Oct 2009
Sydney
Hello,
I have a need for a script to read a text file from a shared folder on a remote Windows XP PC.
I can do this locally using an ethernet crossover cable.
When I went to the customer's test lab, I could not connect to the remote folder. We need to connect through their LAN Routers, because the target PC is not on the same segment.
Using a Windows XP machine, we could connect to \\machine\sharedfolder.
I understand that Windows CE 5.0 cannot resolve IP addresses in the UNC.
On the MP277:
We could "ping www.xxx.yyy.zzz"
We could "ping machine.customer.com.au"
We could not "ping machine" This returned error 53.
We could not connect to \\machine\sharedfolder. We did see it attempt to request from the DNS.
When we used \\machine.customer.com.au\sharedfolder, we got an error 53 and did not see any attempt to request from the DNS servers.
Has anyone else tried to do this ?
Also,
I have read and checked the FAQ 13336639 and I have searched the forum and only found posts which state a similar problem but do not give a solution.
I want to connect 2 plc's (in the same Siemens S7 project) to one HMI (siemens MP277). I am using WinCC flexible. I have done this in the past...
5,503
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
171
Hi All, I currently have an damaged MP277-8" Touch panel (6AV6 643-OCB01-1AX1) which I am able to backup (.psb) via ProSave. We are in the...
2,859
I need some clarification about uploading the HMI file from a Siemens MP277 to edit it in WinCC. Although the machine manufacturer is no longer in...
1,361
First off, I am not a Siemens guy. I am trying to help a customer who bought an older machine with Siemens equipment in it. So far I have had no...
3,650
