Siemens MP277 to CompactLogix
bentleya
Nov 2002
NE KY
69
Hey guys & gals,
Did a quick search and couldn't find anything, so....
I'm having a terrible time trying to get a Siemens MP277 to 'talk' to an L32E CompactLogix (ethernet). I have created a new, basic HMI program with one tag, trying to get it to read the Compact. I have the IP's set correctly, and can talk with either on the network (with respective programs, i.e.: RS5000 to CompactLogix). I can program the HMI thru the network as well. The 'tag address' is exactly as the address within the PLC. I have the 'connection' setup for AB Ethernet on the HMI.
I've used many different HMI's and have never had so much trouble trying to get something to talk, I'm guessing it's normal 'Siemens' to over-engineer something....
Any thoughts?
Additional Info.
I forgot to mention, the same software will work on the Runtime on my laptop. It will not work on the MP277.
Siemens MP277
Yes, the IPs are set.
When using the 'runtime' on the laptop (same software that is downloaded to HMI) it will work fine. Download the program to the HMI and it doens't work???
Do you have duplicate ip addresses?
Try the Siemens hotline
18003337421
Thanks for looking at it....
Yes, I can ping either.
I actually use the Siemens Wincc to program the HMI thru the ethernet connection, no problem. I program the CompactLogix thru the ethernet connection. No IP conflicts.
I do get an alarm or warning, it says something like "interface [ip address]cannot be opened."
Oh, thanks for the number. I've been working thru email with Seimens. They sent me an example which was very simple. I had it exactly as they showed....nothing.
Siemens cold line
Tried the Siemens Hot Line....no ideas...
Tried cross-over cable, straight thru... nothing.
No, no Control logix.
I've got many SLC's, and several CompactLogix.
I've got other HMI's working with Compact's with no problem.
I think the 'clue' is that the software will run on the PC with no problem, but downloaded to HMI, problem.
did you have tried to ping any device from the HMI windows.
It has no choice to be hardware because you can see it in wincc flex runtime....Does the download works fine but the screen show the entry with "#####" or you can't download at all ?
No problem downloading thru the ethernet network.
It shows "#####" when trying to access an I/O.
It's kind of like it can't open the comm port....
did you tried another variable ? did you try with your runtime running beside ?
Have you tryied to update the firmware (OS) just in case ?
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
164
Hi All, I currently have an damaged MP277-8" Touch panel (6AV6 643-OCB01-1AX1) which I am able to backup (.psb) via ProSave. We are in the...
2,841
I need some clarification about uploading the HMI file from a Siemens MP277 to edit it in WinCC. Although the machine manufacturer is no longer in...
1,357
First off, I am not a Siemens guy. I am trying to help a customer who bought an older machine with Siemens equipment in it. So far I have had no...
3,644
I currently have 4 siemens mp277 10 inch touch screens I deal with. Lately 2 of them have been giving erratic touch screen results. To specify...
1,790
