Siemens Multiple HMIs
JasonWade
Oct 2005
Preston
160
Hi
Does anyone know a neat way to allow multiple (x6) identical looking HMIs (TP700) to talk to one PLC (315-2dp/pn). Although they all look identical, each one controls a different section of the machine.
I am trying to avoid having 6x HMIs in TIA portal all with slightly different tags, and then having to edit 6 times to make one change.
At the PLC end I was thinking to have a data type 'HMI' and declare an array of 6 of these.
In the absence of a better way I am trying to use internal tags for all the buttons/fields on the hmi, then multiplex these tags to the arrays of plc tags.
Im hitting a problem with pushbuttons though. When I try to use a multiplexed internal tag in the pushbutton events I get 'This value is invalid'
Does anyone know why?
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
194
Hi, I have been successfully sending emails from a Siemens Comfort HMI (TP1200), configured with a "Gmail" address via VB Script. The VB...
2,302
Hi, I'm curious if anyone knows of a way to print a PDF from a Siemens Comfort Panel HMI to multiple locations. I can print a PDF to a single...
2,315
1,562
Hi Guys. A vendor is delivering a non GMP machine with a 1500 CPU and 4 panels. one TP1200 and 3 TP700. Im searching con/pros for according to...
2,110
