Siemens Online Hardware Config
JOLTRON
Aug 2006
MI
692
Hello all,
I have been given a program for a machine that we have. I went up to the machine and compared all the blocks. I took all the ones that did not match and made them so.
Then I wanted to check the hardware config. I try to go online and it tells me it doesn't match, from that point there are 2 options. Use current for diagnoses or upload config to PG. I picked upload, I couldn't see any differences that jumped right out at me. And I couldn't save the online config to my project.
Any ideas???
The few posts I have read all deal with uploading and saving FC's, FB's and so on.
Thanks for any information you can give.
I contacted the builder and they say the copy I have was the origianl :(
He's talking about the Hardware Configuration, not the code.
Joltron, this is a fairly common message, and usually comes up when the installed hardware has a slightly newer version number than what is in your hardware catalog. In fact, it happened to me yesterday when I interfaced to a machine with a 343-1 card. Even though I have the latest hardware catalog updates, the version number was newer than what I have in the catalog.
If this isn't a new machine and the version numbers are not recent, try updating your catalog and see if the message goes away.
Of the blocks I compared only 4 of the FC's didn't match. I didn't bother comparing db's.
93
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,248
Siemens S7/TIA v16: "Overwrite if object exists online?" HMI loading message... Thus far, I've just been ticking this box, just to get the HMI...
787
Good Afternoon. I am having a problem going online with S7-400. Attached is the error that I am getting. I have looked at the help file but the...
1,813
Good evening, I am trying to get online with an S7-300 controller. I am new to Siemens. I can view the CPU when connected, and open up the blocks...
1,309
