Siemens PCS7 info needed, please
geniusintraining
Jun 2005
SC
8,277
Hello everyone,
I have a customer that has the below parts on his system, they are wanting a trainer so they can practice/train... If I built them a S7 300 trainer digital/analog would this help them? I know very little about PCS7 but it looks like it has an embedded 416 DP2 but I also see some 300 cards so thinking this would be Profibus??
Does the PCS7 run on Step7 (PLC side, not HMI side) or is it a different software all together?
Best regards
Mark
SIMATIC PCS7 BOX 416 COMPLETE SYSTEM BAS
KEYBOARD SIMATIC PC INTNAL, USB (G)
NME -LCD 1970VX-BK 19" MONITOR
CABLE POWER PG/PC 3.2M
SOFTWARE PCS7 SFC VISUALIZATION V7.0
CONNECTOR PROFI 12MB 35DEG W/PG PORT
CONNECTOR PROFI 12MB 90DEG W/O PG
RESISTOR PROFI TERMINATING
SIMATIC PCS 7 I/O SUBSYSTEM HOT SWAPPING
HARDWARE BUS UNIT ET200M 2/40MM I/O MOD
MODULE INPUT S7300 8AI 16BIT 40PIN ISO
SIMATIC S7-300, ANALOG INPUT,SM 331
MODULE OUTPUT S7300 8AO 11/12BITS 40PIN
SIMATIC PCS7, RED. AI8 MTA
SIMATIC PCS7, RED. AO8 MTA
SIMATIC PCS7, TC MTA
CABLE,40PIN-FRT-CONN-DB50,3M
SITOP PS 2PH,120/230-480V,DC 24V,10A
ELECTRONIC DIAGNOSIS MODULE
CABLE PROFI STD CABLE PER METER
TOOL PROFI FAST CONNECT STRIPPING
MODULE INPUT S7300 16 DI 24VDC 20 PIN
SIMATIC PCS7, DI16 MTA
CABLE,20PIN-FRT-CONN-DB25,3M
SIEMENS WILL PERFORM STANDARD TEST PROTOCOLS TO VERIFY PROPER WORKSTATION AND CABINET INTEGRATION (LEVEL 0 FAT).
SIEMENS WILL PROVIDE A KICKOFF MEETING TELECONFERENCE, AND THE SYSTEM INTEGRATION AND TESTING SERVICES PER THE ATTACHED DOCUMENT.
Hi Guys, Please, is 6ES7658-4XX58-0YT8 #K1-30 Trial Version/License OR Runtime License OR Engineering station AS/OS License? SIMATIC PCS 7 V9.0...
1,318
Hello All, I am not very familiar with the Siemens architecture however, I was looking into a possible application. The current Siemens PLC is...
4,232
We've used Acronis previously on site to take images of PC's and I thought it would be beneficial to make use of the continuous backup function in...
1,295
Dear friends, I recently installed Siemens PCS7 V8.1 SP1 on my Windows 7 Ultimate. I'm a new player in the field of PCS7. I have problem while I'm...
4,333
Dear all i am using PCS7 V6.0 SP2.we are planning to add totalizer and one timer in CFC and display the value in Wincc.How to do the program in...
1,845
