Siemens pcs7 starter
I use PCS7 but it is most about continiously adaption, rebuilding and optimation of bigger systems. I have never heard about starter packages. You should have a talk with your dealer about it, and also about the pricing.
Here is a link to the minimal PCS7 configurations:
http://support.automation.siemens.com/WW/view/en/24023824
And a link to PCS7 box ( I have never touched it myself, but it looks ...eh... cheap).
http://support.automation.siemens.com/WW/view/en/47059870
Edit: PCS7 box V8.0 pdf link:
http://support.automation.siemens.com/WW/view/en/57264625
BTW, have you done PCS7 before?
Kalle
I currently use AB. software.
we have PCS7 and I have been around it some. (Mainly just troubleshooting our profibus instruments etc).
I would like to work at home to just learn the system,it seems a lot easier to do the "control" portion than the ladder logic I'm used too.
Just wanted to know if they might have a "cheap starter" like AB.
THANKS.
Can anyone advise how easy it is to get an existing PCS-7 system to interface with an S7-315 on Profibus?
We have a machine which we would like to sell a repeat of, the customer wants it integrated in their PCS-7. I thought rather than put a new bit of hardware in and program from scratch, we could re-use our existing code and just have some signal handshake between the PCS-7 and our 315.
Here is a link to package integration in PCS7:
http://support.automation.siemens.com/WW/view/en/39203658
If you just want a few signals f.x. that the machine is running, has error, is shut off, prod.counters, start, reset, ...,you should keep the program as it is and exchange data to the PCS7 via DP/DP coupler ( you didn't tell but I recon both the 300 and the 400 are DP masters).
When / If you (have) read the pdf, we could eventually discuss more afterwards.
Kalle
KalleOlsen,
Thanks for the reply I read the article. Two immediate concerns 1) The program is already written, the PDF seems to be for new projects. 2) I have written it in TIA V11 and the instructions appear to be for Step 7 V 5.4.
I do just want to do a simple transfer of a few signals. Couldnt it be done using Get/Put?
Hi Guys, Please, is 6ES7658-4XX58-0YT8 #K1-30 Trial Version/License OR Runtime License OR Engineering station AS/OS License? SIMATIC PCS 7 V9.0...
1,329
Hello All, I am not very familiar with the Siemens architecture however, I was looking into a possible application. The current Siemens PLC is...
4,246
We've used Acronis previously on site to take images of PC's and I thought it would be beneficial to make use of the continuous backup function in...
1,301
Dear friends, I recently installed Siemens PCS7 V8.1 SP1 on my Windows 7 Ultimate. I'm a new player in the field of PCS7. I have problem while I'm...
4,347
Dear all i am using PCS7 V6.0 SP2.we are planning to add totalizer and one timer in CFC and display the value in Wincc.How to do the program in...
1,845
