Siemens Profibus CP342-5 Card??
RPax
Feb 2004
125
Hi, this is probably a shot in the dark but is there anyone out there that has used a Profibus CP342-5 card. I'am trying to use the Siemens FC3 Function that retrieves diagnostics from the card but am having problems obtaining a list with diagnostics.
In the Dtype 0 Mode, it gives back a station list of stations that have been configured incorrectly, disconnected from the profibus line etc however it will not report back a slave with diagnostics such as a slave with an analog card with an overvoltage error.
In the Dtype 1 Mode, it will report back diagnostics similar to above ie disconnects, overvoltages etc which is what I'am looking for but it will only give the most recent error. So if 2 or 3 errors of such kind existed then only the most recent one is reported.
Is there anyway I can simply get a complete list of slaves with diagnostics using this function so I can report back to a scada system. Appreciate if anyone has anything on this.
Just something from memory, Im sure you can download a function block called FB125 which covers profibus slave failure amongst other things.
hope this is some use to you
steve
Dose anyone have experience with Beckhoff FC3121 profibus master PCIe card connected to Siemens CP342-5 as a profibus slave? The data retrieved...
17
4,809
Hello All, Just want to pick your brains a minute as mine is now dead :) I have a Siemens 315 PLC and I have a ABB drive (ACQ810) on Profibus...
5,222
i have a siemens cpu314(without profibus port) with a cp342-5 profibus card on the rack....if i try to add slaves to the network it shows them as...
3,318
Hi, I am replacing 2 Siemens S7 PLC's with a Control Logix Processor. I have decided to use 2 CP342-5 Profibus DP modules to replace the...
3,879
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
551
