Siemens S7-1200 PLC With Password
Ramsri
Apr 2014
coimbatore
40
Hi all,
One of My team mate has enabled Protection of the PLC code & downloaded the PLC Code's without typing the password. Now the PLC is not accepting any changes without password. How can i reset the CPU? Is it possible with Siemens MMC(n)
Try a blank Siemens SD card. insert while the PLC is off and restore power. Try it a couple of times, and you should be able to recover.
Otherwise you can probably get Siemens to unlock it for you.
I haven't heard of too many cases of Siemens unlocking PLCs, at least with the newer generation.
If the 1200 is using a memory card, it is an SD card that you can use in your computer in a standard SD card slot. There are 2 hidden files, but if you delete everything else, it should delete the program. I think the PLC should be able to be used after that.
There are ways to do a factory default without the SD card, but adding the write protect password disables quite a few of them (at least without the password). If you don't have the SD card, I'm not sure what the solution is.
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,880
Dear Experts, Please, kindly guide me through how to read data from ABB PLC to S7-1200 Siemens PLC. I want to use Siemens S7-1200 PLC to read data...
450
I've got a whole bunch of L8's and a whole bunch of UDTs that use custom string lengths, but can't seem to figure out how to get these to...
536
Hi Complete newcomer to S7 so go easy on me... Siemens S7: What cable do I need to connect S7-1200 PLC to HMI? The touch screen is one of these...
2,611
Hello all, PLC-programming noob here. I have multiple clients accessing some data on my Siemens S7 1211C PLC; some OPC clients and some direct...
30
8,345
