Siemens S7 1200
geniusintraining
Jun 2005
SC
8,287
So I made a simple program and my outputs are not going true??
It looks like the program is correct as in the watch table I can see the binary bits turning on and off (1-0) and I am moving them to a output word, but the bool address are staying low
See attached PDF's of the screen shot and program
The PLC is in run and a simple latch (another program) was making the outputs turn on and off but not this one??
What am I missing? any ideas??
Thanks!
So.... it looks like I need to go back to school
The second set of bin 1/0's are the outputs, once I get the full understanding I will post more for others like myself (that don't get it)
I think now I need to do a mask... back to the books :)
Hi mark,
I dont use this software (yet)
Could you tell me what data type IEC_Counter_0 Count value is?
As a test hardcode a value into the move and try that
i.e move W#16#FF to QW0
Is there AND/OR Word instructions?
If you move to a word and you want to see what is happening, monitor the two bytes that make up the word.
Bit 0 of the accumulator does not correspond to Q0.0 when a word transfer is performed.
Example from S7-300:
Hi Guy's
OK, I just learned what LD is talking about (the long way), so.... I tried adding 256 to the counter to but that on put a 1 into the second byte
Then I did a MOV to QW1 this did the same thing... but when I watched QW1 it was doing what I wanted
See the attached, I would of thought I just needed to address the MOV to QW1, but when I address that in the MOV it does the same thing as QW0
I will try the swap and let you know
Mark
hi Mark
The software has quite a few bugs in it but it is a big improvement on step 7 ,Can`t Wait for the full version coming out in november to program the s7-300 series as well that should be interesting
regards
Mel
Hi Mel,
I like it... if you can (like you said) look toward the future this can be a very nice system, it has given me the error screen a few times and had to restart, so I learned to save often :) , but its new so I expected some of that.
I do wish that they will make a UN-do buton, I have made a few changes and wish that I could hit the undo/back/ctrZ
Thanks again...
Mark
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
286
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
149
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
194
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
325
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,984
