Siemens S7-200 PPI cable issue
zer0net
Jul 2011
canada
24
Hello,
I just got siemens PPI cable. When I connect it to my xp computer it automatically installs it as generic human interface device like keyboard or mouse, when I try to change driver it doesn't let me.
any help will be greatly appreciated..
thank you
This is normal for this cable, what errors are you getting and why do you think you need to change the driver, this cable will not show up as a com port, in MicroWin you will just choose USB
Thank you for reply,
you are right, it is working with microwin and S7-200 without the driver however, I cant seem to establish a connection with my TP177A HMI and WinCC Flex 2008 SP1. So I automatically started blaming the cable.
Any thoughts on why WinCC cant connect to HMI?
Thank you
Alright.. its solved.. stupid me... the OS of the HMI was of different version than that of my WinCC... Once i updated the OS everything was good..
Thank you all for your time.
We have Siemens S7-200 PLCs in different machine. To get access to their program, I have arranged a USB/PPI Multi Master communication cable but...
7,504
Pls. introduce the HMI for S7 200 (PPI) or if i have proface 4000 series , can it connect to PLC SIEMENS S7-200 via PPI Port:thumb:
3,766
Hi, I am having trouble connecting to a Siemens S7-200 PLC in Citect. - Citect Version: 6.1 SPB, - Driver: SIMPPI 1.00.03.001 - Siemens...
2,688
Hello. I have recently work with serial rs232/ppi cable. I have conected s7-200 with Citect scada without any problems. I have just select RS232...
3,945
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
