Problem in selection of Siemens USB/PPI cable for S7-200
AB2005
Nov 2006
Lahore
318
We have Siemens S7-200 PLCs in different machine. To get access to their program, I have arranged a USB/PPI Multi Master communication cable but facing a problem that during communication set up, there is no option (see attached pictures) to select that cable. If I select PC/PPI cable, communication error appears. Please assist.
Have you installed the cable drivers?
Re-install microwin and/or download sp9 from siemens web site.
Are you using v3.2 SP2 as that doesn't support USB PPI cable maybe later SP does, I use the latest v4 SP9. I've just started to use Siemens so maybe someone more familiar could be of assistance
Rob
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
40
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
174
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
135
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
144
Hi all. Simple as simple can be, I don't understand what's happening. I'm toggling he OSR on, GX_LUB_PUMP1_LEAD should switch. It doesn't. The...
27
669
