Siemens S7-300 connection to tp170b
jacokapp said:
How do i setup the tp170b on profibus to the plc without useing protool?
You do need to load the application to the HMI somehow (Pro-tool or WinCC).
Anyways, to get going you need to get into the configuration settings of the panel and select Profibus as your communications, the address of the panel, as well as the speed and select if the panel is the only master on the bus or not.
Not sure what you are trying to accomplish though!
Hello,
If I remember correctly on TP177B you go in Control Panel (since it is Windows based OS) and you have Connections and there you can choose type of connection...
Without Protool? Then the only option would be WinCCFlex.
Without one of them, it ain't gonna happen.
I had to use a standard operating system ,given by the supplier,had to export my source code using a export tool and then import it to the TP,also had to set the profibus addres in the aplication.
HI, I am new to Siemens and having difficulties connection to the S7-300. I have recently been connecting to the 200 without a problem so assumed...
2,608
Hello All, I am having trouble setting up a S7-300 MPI connection using Simatic Manager 5.5. I am trying to use an OPC server with a S7 MPI...
3,905
Hi, I encounter a problem trying to get online to a CPU315, This CPU is part of a MPI network with multiple CPU including a CPU414, When I do...
1,495
I want to take some data from a Siemens S7-300 system to the other system through profibus system. I configured a Profibus node in the hardware...
2,510
Hi folks, I'm having trouble connecting to a Siemens Simatic S7-300 CPU 315-2PN/DP via ethernet from a PC using Hyperterminal, I have the correct...
28
21,942
