Siemens s7-300 downloading error
PLC_talk
Oct 2006
p
50
Hello All,
I am facing problem while downloading the S7-300 ladder to CPU. I tried browsing the Forum if someone had this kind of error, but couldn't come across any.
The ladder has been compiled tested on simulator first & runs fine, but when I download it to CPU it does not allow me to download any FC's FB's OBs. I checked the MMC card & its present. I have tried Mreset , online deletion of all blocks in the CPU memory & even downloading a truncated ladder which contains just OB1 with 1 N/W. Still the problem persists.:mad:
My hardware configuration is CP315-2DP, CP341 in Processor rack, Rack1 -Rack 5 containing I/O cards . All racks connected on DP/Profibus using IM153-1.
Any suggestions welcome.
Thanks,
Make sure that you are not trying to download any marker memory, inputs, outputs or data blocks that exceed this CPU's limitations
While downloading the FCs & FBs it gives "The Block is too big" . The actual size of each is between 20-30 bytes.
Hello all, Newbie in Siemens, I want to ask if there will be any issue when I download the instance datablock of a certain Function block? Also...
4,431
106
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,459
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
699
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,075
