Siemens S7-300 upload and merge question
richxie
Jan 2007
Ontario
31
Question of Siemens S7-300: I have a copy of the program (dated 2002), but I'm not sure it's the same in the PLC. How can I get online with this copy without losing descriptions? Is there a upload & merge function?
you can compare online/offline blocks if you are not sure if your backup is up to date..
Simply click on 'Blocks' on the left side of Simatic Manager Menu and then click Options/Compare Blocks.
If you want to compare only one block, you can select it and so the same thing.
Thank you emokar.
I did the blocks compare, and found differences. What can I do now? I tried upload. It just created another program in Simatic Manager.
What will the "update" button do in the "blocks compare" window? Does it upload or download? I don't want to change logics in PLC, but how can I get all FBs and FCs out?
If I'm thinking the correct thing, the update your talking of is when you have both blocks open side by side.
If that's the case, it does a re-compare after you have maybe modified a part of the code as per the PLC. It the shows you if the blocks are the same or other differences.
N
Hi i'm new to the siemens scene (most of my experience is with Allen Bradley )and need help uploading a program from a machine. the setup is the...
8,217
neto71
N
119
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,475
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
720
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,082
