Siemens S7 and setting up acquistion of dynamic IP adress
blackslipper
Nov 2005
North Carolina
47
Hi hI
I am having a problem when using the S7 via the ethernet, using the CP 243-1 IT module.
The problem is any time i turn off the system, and restart is seems that the IP adress that I assigned to the PLC was taken up by another device on the network and therefore I have to go through the whole process of setting up through the internet wizard another IP adress I am wondering if there is another way, I.e. automatically the PLC will grab any available IP adress between some range for example..
Can this be done and how?
If not any other suggestions on how to deal with this sort of thing?
I don't know if the S7-200 supports DHCP (or BOOTP), but that probably isn't what you want anyway. It would be best if your network administrator added an exclusion to your DHCP (or BOOTP) server, and let you use the addresses in the exclusion zone as static IP's for PLC's and such.
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
845
Hi, Is there an easy way to limit the input tag by using min and max tags from the PLC? Thanks
1,268
Hi guys I have a siemens 1500 with a cp1543-1 industrial network card, which I would like to connect the factory network to my plc , so I can...
1,053
I have had issue after issue with Siemens Simatic Manager, it worked great and now all of a sudden it died. I have removed and reinstalled in...
1,723
Hello All, Want to know what should be the correct setting for the Measuring range for connecting this instruments to my AI Card? So I am...
2,399
