Siemens Step 7 and Function Call know how protection problem
e_unit79
Sep 2005
Dayton, Ohio
I have recently encountered a problem with a Function Call being know how protected. I cannot not open the Function Call to edit the ladder logic for a client. The Function Call is not a Siemens proprietary Function Call. The function call was written and protected by a Controls Engineer in the past for job security reasons. If anyone can give me advice or where I can find solution would be wonderful.
sanjay_snj said:
use "DBFViewer"
open "\ombstx\offline\0000000?\SUBBLK.DBF"
change field "PASSWORD" 3 to 0
sanjay
Just to clarify sanjays answer.. the folder path and SUBBLK.DBF file will be in the relevant project folder which will normally be in the S7proj folder in your siemens directory....
JT
Dito on can opener. I strongly recomend you don't mess with the insides of that FC or FB. The guy protected it for a reason. Try to use it from outside but LEAVE IT ALONE. You can write your own stuff and use the function as reference.
I would like to thank all of you for your advice and help especially since I am a recent college grad and started a new career in Controls.
Hi, is it possible to read the name of the steps in an S7 Graph sequencer? In the parameterinterface there is, for example the parameter #S_NO...
21
7,210
I am having problems understanding a program i am trying to troubleshoot. The reason why i am having difficulty is because its written in function...
9,276
Siemens Step 5 Function Blocks Post #1 Hi everyone, this is my first time on this forum and i thought i would just test the water. So here...
38
17,550
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
253
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
