L D[AR2,P#0.0] vbmenu_register("postmenu_293952", true);
OHHHHHHHHHHH! that changes everyyyyyything!!!!!!!
I thought you wrote it in STL as it appears .........that was just to transmit the data through the forum. I suppose it is difficult to extract just the one block from the project and attach it in block form.
If I may , intrude on your extensive patience once more today ...........
I am now exploring this very thing.
I made a new object in the Manager. FC223
Now I open FC223 and put what ever I want into it using ladder logic commands.
Then compile from the file menu.......
My first attmempt has errors and will not compile, I will digest the new info and keep at it.
OK I am looking at your block in ladder and switching to STL and then working through the variable declaration table at the top of the page.
I should have it in a couple hours. I can read about the variabl table and the struct type.
This is an amazing functionality.
I assume this source code has to be included in a new project to take it with me as I collect a bag of favorite bits.
This makes up for so much of the difficult beginning.
Thanks so much, you may have just saved me on this one.
I may not be able to help much, but I will check back and see if I can "give back" to the forum.
I have never received any usefull help online before so this is quite nice.
Thanks again to all,
