Siemens TIA portal software
Jim G.
Nov 2007
Georgia
187
I recently got a quotation for a Siemens PG computer with TIA Portal V14 SP1 installed as a ready-to-go package to support a new line we are installing. My management wants to buy only the software and load on a standard PC. Is the PG computer from Siemens worth the price? What kind of specs would I need to look for to run this software on a standard laptop. Any recommendations? Thank you in advance for any help.
The Siemens PG / Software bundles make sense, if you don't have any Siemens licenses.
If you subtract the single license price for the Siemens software from the bundle price with the PG, you get a high quality and robust notebook for a relatively low price.
Also it has some interfaces like MPI/Profibus and a Siemens card reader which is sometimes useful if you have to deal with the classic S7 line of S7-300/400.
The Siemens PG, at least the one I used to have, had three separate NICs in it - two wired and one wireless. I found that to be more useful than I thought it would be.
If you work with S7-300/400, then your company really should have at least one PG around for clearing the (non-windows formatted) memory cards. Profibus is nice as well, for older systems.
If you plan on using the newest software, getting Portal pre-installed is a huge time saver. Honestly, probably saves a day. You'll probably need to add some other options like safety, though.
I use both NICs simultaneously plenty, but textra NICs are easy enough to add later with cheapish dongles.
If you don't get the PG, you'll need a decently specced system. Siemens support site has the recommended specs for Portal. Make for sure you get a SSD, preferably a big one. Mine is 2TB, but that's because I run a lot of VMs.
TIA portal will run good an a good computer. Never had any problems since I bought my newest one.
A day to install? The installation takes 30min? :)
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
115
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
474
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
233
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,550
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,228
