Siemens TIA Portal Step 7 V13
lefeverj
Nov 2011
Texas
18
I am fairly new to the Siemens TIA Portal but it seems really powerful. I have a simple but complex task that it seems I may be able to complete thru many different routines within the tia portal. I have up to 23 different outputs that I can select in which typically (4) of them will get used and then followed up with (1) remaining flush material. I need each material to load by itself per the amount requested by the HMI. The operator will also select the material thru the HMI..ie. material 1, material 2, material 3, material 4. I have moved those values into a data block on the HMI. I could link that data block to the PLC. My thought was then to complete each material load based on the amount of material requested by the operator thru the HMI and then repeat for the next material. Could this be done with a VB script, funtion block, recipes, etc? I am looking for the simplest path of writing code.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
448
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
215
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,530
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,195
Hi, I want to initialise some tags on first scan only. As they are related to wall-clock time, I want to do the initialisation when the PLC first...
1,184
