Siemens TIA portal V12 IP addresses
Gordon Coyle
Aug 2015
Glasgow
Hi All,
I am just learning to use Siemens TIA portal V12 (and PLCs) and having difficulty with the IP addresses when connecting from HMI and PLC (ST-1200). I have fixed IP addresses from the company IT guys and thought that I had changed both but when programming they changed back to 192.168.0.2. Is there an easy way within the program to assign IP addresses?
I have found the Assign IP address button but it does not work?
Thanks Gordon
Hi! Welcome to the forum.
What IP is changing?
If you set the IP of the PLC/HMI in TIA under the device configuration, it should not change by itself?
I think you have to set the address in two places.
I think, from what you wrote, that you are able to go online with the PLC and change the IP address using that Assign IP Address function. That's the first thing you need to do.
Then in the program, offline, you need to right-click the controller and select Properties. On the window that opens, look for the PROFINET Interface section, then the Ethernet addresses option. That typically defaults to 192.168.0.1 for one device. You need to enter the IP address for the controller here as well. . The controller resets the IP address to whatever is configured here if the option on the windows "Set the IP address in the project" is selected, which I think it is by default.
Hi guys,
Your right tim2 I was able to change the PLC IP address but could not work out the HMI, thanks for the help been able to connect both devices and upload a simple program :)
Thanks for the help Gordon
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
446
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
211
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,525
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,182
Hi, I want to initialise some tags on first scan only. As they are related to wall-clock time, I want to do the initialisation when the PLC first...
1,175
