Siemens Tia Portal V14 and V16
marshjhm
Oct 2006
Spokane, WA
38
Is it possible to install Siemens Tia Portal V14 on a machine that already has V16 installed? Or do I need to create a virtual machine to install the V14 on. I Need both versions because I have two plants that are using these different versions and their local people do not want me to convert them.
I have v13, v14, v 15.1 and v16 on the same Windows machine. But I installed them in that order. never tried installing an older version after a more recent one is installed.
Save yourself the headache and install it on a separate VM and back them both up regularly.
Using a VM was my first thought, but how do I get the licensing to work? Will I need to move to a different licensing model, can I put the key on both machines, but only open one at a time? Still looks like I'm in the same quandary.
Yep
2 - VM's need 2 licenses
or you keep moving the license back and forth between VM's
Remember 1 V16 license works for V16 and V14
It's possible to install Automation License Manager on your host machine, and share over the "network" (the network would really be virtual).
Floating License means any computer on a network can use the license. In your case, only 1 VM at a time could use the license stored on the host machine.
Download for Automation License Manager for separate install:
https://support.industry.siemens.co...alm-tia-administrator-authors)?dti=0&lc=en-WW
Look at section 3.5 of this manual:
https://support.industry.siemens.com/cs/document/102770153/automation-license-manager?dti=0&lc=en-DK
Yep
Could you not put the licence on the host and share that file location to each vm so basically share 1 licence, of course you could only use one VM at a time
In theory yes....seeing that you can have floating licenses for multi site tia portals.....just not sure if a normal license can be used as floating license...Sure Jesper will sort this out when he gets online
There should be no problem installing on the same VM. V13Sp2 to 16 all work on Windows 10. With this setup you can open multiple programs at a time from multiple versions.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
446
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
210
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,522
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,179
Hi, I want to initialise some tags on first scan only. As they are related to wall-clock time, I want to do the initialisation when the PLC first...
1,173
