Siemens USB Prommer in Windows
ThePortLion
Oct 2007
Ireland
58
Hi guys
I have another thread on here on a plc that is password protected and this is really a follow up on that but as it is a side issue i thought i'd start a new thread.
Is it possible to get a siemens usb prommer to show up as a physical drive in windows?
It seems to be locked to Step7/Step5 which makes sense.
The reason I'm asking is that I want to open a 128k S7 flash eeprom card
(951-0KG00-0AA0) outside of step7.
Otherwise, would a PCMIA card reader work in this case?
Thanks in advance.
I have COM Profibus 5.1 w/Hotfixes 1,2, and 3 applied running on an XP platform. I am attempting to import a bus configuration via the USB...
6,379
Does anyone know where there is a compatibility list of what software packages (obviously Siemens) the external prommer works with?
5,915
Hi there, So i have the siemens comfort tp700 hmi. I want to print using printserver and laserjet, but is there any way that i can change the path...
1,578
Hi all, Before the computer decided to update windows 10 last night my cable was working fine.....now its not. Does anyone have the drivers...
2,490
Hi guys I need to transfer a tia license for a couple of days from one pc to another via usb and then back again after wards. What is right way...
6,902
