Siemens version of RS5000 trend
Secret
Aug 2005
Beds
55
Morning all,
We have a niggly sync issue in a S7-300 that would benefit from trending a couple of memory bits and outputs in a RS5000 Trend style.
Is there such a tool on S7? I've done a search on the forum but couldn't really see anything of value just stuff for trending on HMI's.
Cheers
As far as I know the 300's don't offer a trending option. Only the HMI software. If you do have WinCC flexible installed you could write a simple trend program then use the "Runtime" to monitor it.
I do have WinCC Flex any ideas off the top of anyones head how quick you can the set the update times for monitoring doing it in this way? I haven't used trending on HMI for years but it wasn't that great when I did.
The fastest flexible will log/trend values is 1 second. To go faster you have to log it in the plc and do buffer bit trends to get it up to flexible.
Anyone know how I can convert DTL to DATE type? This rung is trying to determine if the system is in calibration by subtracting the current date...
595
I have converted a Siemens OP7 program to a new Delta DOP107BV. It is all working as expected except for the timer values. I am using MW36 as the...
952
Excuse my ignorance. I've only worked on Mitsubishi Q-series PLC's, now I'm working on S7 for first time with no training. I'm trying to set up a...
1,192
I have a nice project in Visilogic that I have been asked to re-create in Tiaportal/Siemens. (Bosses / maintenance want to standardise on one...
1,324
Hi All, I'd like to inquire about the possibility of converting a program currently used on Delta PLC to be compatible with Siemens PLC using...
1,437
