Siemens WINCC trending option
dbozic
Oct 2013
Zagreb
74
I need recommendation for a best solution of trending data on the PC.
We have a S7-300 with a PN port and S7-300 with DP/MPI port.
We would buy for this PLC a communication processor with PN port(6GK7343-1EX30-0XE0).
This PLCs would be connected over ethernet switch with PC.
The goal is to record trends and be able to plot them (at least 1 year minimum)and make reports (which would include recipe steps and drawing a graph of production).
Can you recommend some Siemens software which would be practical for application.
It would be good if there is a database of all production and you can access it to make a report from the timeframe you are interested in. Could you please direct me to the best solution?
If you need some more parameters I will provide them!
Thanks!
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
315
I thought I was nearly finished on this TIA Portal/s7-1212C project (famous last words)... Up until now, I'd developed the PLC/HMI such that the...
1,577
Hi, I have a HMI which is a KTP1200 Basic. Let's suppose USER03 is logged in. How do I create a simple "Lock Screen" that appears if the screen...
680
Hi, At the moment, If the user fails to provide a valid username/password, the image attached appears "Invalid password or user name. Logon has...
1,582
Hello guys, Im using a siemens with WINCC in a computer and need to import to tag´s data fom a specific row in a SCV file, i have a working...
1,706
