simatic 135u analog value
sahin2000
Sep 2004
kocaeli
hi
I have follow configuration,
6ES5922-3UA11 S5-135U CPU922R
6ES5465-4UA12 ANALOG INPUT (0-10v in)
6ES5420-4UA13 DIGITAL INPUT
6ES5441-4UA12 DIGITAL OUTPUT
write FB10
:rlg:ae
BG D KF
KNKT D KY
OGR D KF
UGR D KG
EINZ Q BI
XA Q D
:LW =BG
:LW =KNKT
:BE
PB1
JU FB1
BG :KF+128
KNKT :KY 0,4
OGR :KF+2000
UGR :KF+0
EINZ :F 0.0
XA :FD194
:BE
OB1
JU PB1
:BE
BUT NO ANALOG VALUE ?
My problem,not read analog value.How I can read analog value from sensor(0-10v).
I don't use PW address.(dip swit 128)
ANALOG INPUT manuel ?
best regards
hi I have follow configuration, 6ES5922-3UA11 S5-135U CPU922R 6ES5465-4UA12 ANALOG INPUT (0-10v in) 6ES5420-4UA13 DIGITAL INPUT 6ES5441-4UA12...
5,208
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
170
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
309
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
319
