Simatic S5 115U CPU 941 - Siemens Experts required!!
504bloke
Jan 2005
Down South
2,721
Hi
I have been asked by a customer if this processor
S5 115U CPU 941 with a Ram Card Fitted (dont know the number as i couldnt remove it)
Is able to have an E/EEprom fitted instead as they have lost the program once before due to battery failure and power cut!
They have been told that the user program is too large for an e/eeprom ?
Would this be the Case ?
The 941 was the baby of the range, 2K memory to a max of 18K so very small.
I would have thought that if they could fit the program in RAM then EEPROM wouldn't be a problem.
It there is a limitation then maybe it would better to try to upgrade to a 942 if they can find one.
Bringing an old thread to lite!
The 941 i spoke of above has nearly died..
i have located a 943 series B (6ES5 943-7UA22)
or a standard 943 (S5 943-7UB11)
Just wanted to check are both these units a compatible swop for the 941 i have ?
Secondly what EEprom part number should i be looking for ?!?
The program is around 6K in size.
Thanks in advance
504bloke
As far as I am aware the 943 is compatable with the 941, so you shouldn't have a problem there. I think the only difference is that the 943's execution times are half that of the 941.
I believe that the EEprom part number you are looking for is 6ES5374-1KG11, that is for a 5V 128Kb flash memory card. As it happens, I have a one of these cards going spare, PM me your address if you are interested.
Paul
Thanks in advance
You can download the 941 program into the 943 series B with no major issues. The series B was way faster than series A.
One caution though, when you download to the 943, do not download DB1 from the 941's program into the 943. I forget at what processor # and what version, DB1 became a configuration DB
Ian
Also note that if Db's are used to store variable data i.e. some kind of recipe then you need to decide if the db's are written to eeprom or generated in the startup OB on power up
Siemens S5 941
Hi Guys,
We've got this cup printing machine that has been working fine for the last 10-15 years and last year it started playing up - it would not start up, or if it does, it would just stop unexpectedly in the middle of the cycle etc. We tried pretty everything we could in terms of checking/replacing hardware, contacts and the rest. In the end, we managed to start the machine again, albeit temporarily, and we got the istack that shows what the errors might be. However, I am unable to interpret this information, so , could anyone please assist? I attach pictures of the istack files herewith. Many thanks everyone!
Hi kipool,
QVZ - Time-out from I/Os:
- A peripheral byte that was not addressed
has been referenced in the program.
- An I/O module does not acknowledge.
STOZUS ”STOP” state (external request for
example via the programmer)
STOANZ ”STOP” display
REMAN
0: all timers, counters, and flags are
reset on Cold Restart
1: the second half of timers,
counters, and flags are reset on
Cold Restart
BATPUF Battery backup okay
AF Interrupt enable
Intermittent QVZ (I/O fault) is a nasty one to troubleshoot. I've seen a bad backplane, a bad power supply, and a bad I/O module in relation to this error.
Sounds like it is time for an S7 PLC to replace it.
Hello Dear, I am using a PLC SIMATIC S5 115U CPU 943B my problem that there is no output on CPU (943 B) ⚫️RUN STOP 🔘RUN 🔘STOP 🔘QVZ 🔘ZYK...
2,482
I have a Simatic S5-115U CPU 945 PLC and an Interbus card IBS S5 DCB/I-T This PLC it's from a master machine, which was a part of a complex...
25
9,630
Hello Friends I have in use a S5 115U CPU943B Siemens PLC , the my problem is, that I do not have the procedure to download /upload the program...
3,196
S
Hello, I´m new to Simatic S5 system and need advice about how to get online to CPU 945 (6ES5 816-5AA01). There are two 15-pin connectors in front...
8,101
stan77
S
Dear Friends, We are imported the used machine with Simatic s5 115U with the following modules power supply P.S. 7A/15A CPU 6ES5 944 - 7UB21 /...
6,328
