Simatic S7-200 and WinCC flex RT
Gromit
Jun 2006
119
Hello,
Can I connect an S7-200 PLC to a PC running WinCC flex Runtime?
As I know WinCC flex RT comes bundled with the Softnet LEAN license.
So, the easiest and fast solution should be: S7-200 with Ethernet module - CP243-1 connected to the PC's NIC (Lan card), through Ethernet.
Is this idea OK?
Regards
Hi Gromit.
Yes. You can use WinCC Flex RT with S7-200 and Softnet S7 Lean via a regular PC NIC.
WinCC Flex also supports PPI, MPI and DP for accessing S7-200.
Does the Softnet S7 Lean license comes for free with the WinCC flex RT 128 tags license?
Do I need any Softnet licenses for connecting the WinCC flex RT (CP 5611 A2) to the S7-200/300 through MPI?
Are, they free too?
Thanks in regards.
You can connect via PPI, MPI or DP via the direct drivers - set via the Set PG/PC Interface utility.
You do not need Softnet PB S7 for this and it is not included in the RT license.
The only major drawback is that you cannot setup an additional OPC connection.
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
503
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
763
I have new Siemens PLC / Simatic S7-1200 Need software download to use the PLC Please advise Thanks Wally
2,250
645
