Simatic S7 - 200 Diagnostics / tests ?
Jimsbits
Feb 2006
London
Ive got a box of Simatic s7 - 200's, whats the best way to test them? I've got STEP 7 and can connect to them ok, is there a piece of code I can upload and run on them to perform a diagnostic to check everything is working ok ? Or is there some other utility I can use ?
Any advice would be helpfull.
Cheers in advance
Jim
To program S7-200 you need Step7-Microwin (not Step7 prof. for S7-300/400).
To check the PLC select the menu "PLC" - "PLC information". It returns the PLC data and last errors.
To get familiar with it read the 1h/2h manuals.
http://www.automation.siemens.com/s7-200/html_76/primer.htm
Then refer the system manual:
https://support.automation.siemens.com/WW/view/en/1109582
Samples could be found at:
1.
http://www2.automation.siemens.com/microset/html_76/support/tipps/tt-antriebstechnik.htm
2.
www.s7-200.net
3.
http://www2.automation.siemens.com/microset/html_76/support/beispiele.htm
Cheers Damir !
No experience of these things so wasnt sure if the PLC would report on internal hardware errors.
Now for a day of wiping and checking !
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
101
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
515
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
771
I have new Siemens PLC / Simatic S7-1200 Need software download to use the PLC Please advise Thanks Wally
2,273
646
