Simatic S7-300 Plc
salah
Jul 2003
Benghazi/Libya
22
Hello All,
I have S7-300 PLC, CPU type is (CP315-2DP) and order no. is (6ES7 315-2AF03-0AB0). Can any body tell me what is the capacity of its RAM and is it possible to extend the RAM capcity or not.
I could not find the technical specification for this type of CPU in Siemens website, is it possible to have full information about the CPU type mentioned above.
Thanks alot for your help
Salah Gumma
Benghazi/Libya
Hi Salah.
It has 64 kB work memory. You can find it in the HW Catalog in STEP7.
You can insert a bigger flash card, but the work memory will remain fixed at 64 kB.
I think this is already the most important info.
And with this link you should find more info:
http://support.automation.siemens.com/WW/llisapi.dll?query=6ES7315-2AF03-0AB0&func=cslib.cssearch&content=skm%2Fmain.asp&lang=en&siteid=cseus&objaction=cssearch&searchinprim=0&nodeid0=4000024&x=17&y=7
Grtz
My mistake [although I thought this was 2AF03, can be 2AF02];
but most important is that you must keep your timers, FC's, counters,DB's, ... a little in range and that your not so free to number them compared with the 2AG10 series which followed after the 2AF03.
Nevertheless, here a memory view of the 2AF03
Grtz
Now it is my turn to apologize, djikke.
I dont know what made me think that what you posted was for another CPU. What you posted was correct.
I must be tired.
Dear all can anyone suggest the method to lock the plc or to stop the machine As the customer is not doing the payment of the work please...
2,263
Hi everyone, I'm newbie to plc our plant has Simatic S7-300 cpu 315-2DP and a tp270, SM321, SM322, SM331 the technical support is in another...
4,040
I'm trying to set the clock in the PLC based on the time/date that's set on the HMI. So far this doesn't appear an easy thing to do with Siemens...
5,491
Hi, I have Siemens PlC and I am trying to write program in SCL or other language. This program shut regulate temperature using pulse width...
10,327
Hi all I am using Simatic TP 170A HMI using ProTool 6.0 SP2 with a S7-300 PLC. I need to know how can i change screens on the HMI from the PLC...
7,062
