Simatic SM374 Addressing
ceilingwalker
Mar 2010
Phoenix, AZ
1,589
Hello all. I have a Simatic SM374 (374-sxh01-0aa0) sim module. I am using TIA portal v.18. I can't find this module in my list of hardware devices but read something on Siemens website that said I could select a module similar to it, which I did. My problem is, I can't find any documentation for this module and I don't know how to address it in my PLC program. If someone knows the whereabouts of a document for it, that would be cool. If not, does anyone know how I am to set up addressing for this in my project? Thank you
That simulator module can be any module depending on the rotary switch on the front
So any 16 input or 16 output or 8 in 8 out
Hopefully I made sense
In other words, it’s not in the catalog
I have it installed okay what I don't know is how to create an image table for the I/O. How do I address each bit. I can't find any documentation for it.
If it’s a 16 point card with switch set to 16 input then pick any 16 point input card
Then for example you drag in a 24vdc 16 point card
Now your ib (bytes ) 0 and 1
The first input in the card (in my example) is
i0.0
Make a VAT table (watch table) and experiment
i0.0
Thank you. (y)
Huh, now I have a new problem, since reloading my TIA. I can't connect to my PLC. I don't even see MPI as an option anymore. It shows S7 USB but that isn't working.
I am still having problems getting my sim module to work. It tells me it can't be reached even though it is connected to the PLC. This is what I get.
Yikes, I keep embarrassing myself even further. I didn't have it configured properly. Now that I do, it's working just fine. Where's the embarrassed emoji?????
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
300
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
124
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
202
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
352
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
346
