Simotion D425 Drive Connection to Kepware
russg
Aug 2012
UK
280
Has anyone connected a D425 drive to Kepware before? I've read you need to enable an OPC through scout. We have tried this, but cannot get connection from Kepware.
Russ
My understanding is that you need to have Simotion is its own OPC server, so you might not need kepware at all. If you're using kepware for logging or something like that, then Kepware would be an OPC Client, which is different from the typical usage.
Hi all, I'm trying to bring info from a D425 into TOP Server (same as KepServer). All of the tags inside of the D425 are named variables...
2,266
Help me to read an analog value from Cpu 315 for simtion controller to control the speed of one of the servo motor over MPI. If it is not possible...
3,083
hi i have simotion d425 with smart module line and singel motor module and duble motor module and 3 1fk7 motor all siemens. ok i have problom...
3,815
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
51
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
93
