Simotion
hokie
Aug 2005
GA
76
Does anyone have experience with the Siemens SIMOTION system for multi-axis motion control?
I would be curious to hear any feedback on ease of use, capability, etc...
thanks,
We were in discussion of using it, but:
Siemens will provide a special guidance crew to make it work (So aparently it's very complicated).When buying Simotion for the first time we could not order at our normal supplier but needed to order directly from Siemsns.
To use the full potential of the system you must use Siemens drives/motors etc. (My company works together with SEW).
The price was a little bit more expencive then our current motion controller (Adept). In our experience it is very hard to get the right person from inside Siemens to help you with "special" problems.
In the end we decided not to use the system but choose a cheaper and easier solution for our motion application. (SEW Movidrive with technology function extended bus positioning)
Hello.
I've worked with Siemens Simotion drives two years back. It's all very complex, and about 3000 parameters... As you probably know you can parametrize it with DriveMonitor. I was useing the basic positioner for my aplication. So I got the drive configuration from Siemens, but if I would have to set all those parameters my self I think I would have lost my mind.
The drive it self works fine and does it job realy well. Me and my father(boss) were realy surprised.It positioned +- 0.005 mm exact with max acceleration and max speed. With an spindle that has no backlash.
So basicly once you can control the positioning task throug drive monitor the hard part is over. Then programing in S7 comes in...
POSMOS on the other hand also ofer you the positioning tasks and are alot easyer to use and implemet in you Step 7 configuration. They have their own program to parametrize and control them. It's called SimoCom A.
Hope this helps... if you have any other questions, ask away :p
Regards
Ales
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
58
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
96
Hello everyone! I'm currently working with SIMOTION D410-2 with a CF Card labeled with SIMOTION D410-2 V5.3 SP1 HF9 + SINAMICS V5.2 HF6 From...
527
Hi, I have a program that is mainly coded with Italian comments. I want to find a way to export all the comments and then run them through google...
1,330
Hi, guys, how are you? We want to build the communication between SIMOTION D435-2 and main controller AB 1756-L72S Could you tell us which...
1,760
