Translating SCL Comments with Simotion?
russg
Aug 2012
UK
275
I have a program that is mainly coded with Italian comments. I want to find a way to export all the comments and then run them through google translate to then import them back into the project. I can only find a way to do this for the ladder blocks, but not the SCL blocks. Has anyone figured out how to do this?
Thanks in advance.
You should be able to do this as the tag level. Using a OPC data link and Excel You should be able to pull all the relevant stuff from the PLC, change it, then send it back.
If the comments in the SCL are text preceeded by a double slash e.g.
// a comment
then they will not be part of the project texts that can be exported. You will have to copy paste these manually, translate them and paste them back. You could write an app that will automate this - it all depends on the volume of comments in the SCL
// a comment
Thanks for the reply. Is this something you have done before? Or know someone that has done this before?
I need to translate comments and symbol list in a Step7 project from italian to English. I know both languages but it seems very time consuming...
3,385
Good Morning , I have a MicroLogix 1500 program I would like to convert to a CompactLogix 1769-L18ER. Can I use the RS Logix 5000 Tools/...
4,022
I have a s:7 status problem which is, as I could found related to the 0-7 racks of the plc (PLC 5) . However I tried to search in the GSV block...
2,986
Hi, I have a PCE instruccion error (PCE 103), due to the status file S[8] in plc5 when tralslating it to rslogix5000 . So my question is, how do I...
2,262
I have a siemens PLC 300 series. all of the programe from block names to the code, SCL is in german is there a way to translate this to english?:furi:
2,126
