translating german to english
Not sure if I've understood exactly what you want.
In Simatic Manager you can switch between English and German (under "Extras" this changes the commands and the IO from German to English. I don't have a copy of SCL available at the moment, but since it is IEC 61131-3 compatible I would have thought the commands would already be in English.
What you can't change, of course, are any comments - unfortunately that's probably exactly what you want to change!
this is what I got
Looks like the camands are in english but all off the discriptions are in german.
A "M66.6 Stempel oben" // "M68.2 Stempel unten"
FP #FP_Stempel
= #IM_Stempel
I also tried changing them in the symbol table but I got erros in the code block???
Hi, I have a program that is mainly coded with Italian comments. I want to find a way to export all the comments and then run them through google...
1,320
I need to translate comments and symbol list in a Step7 project from italian to English. I know both languages but it seems very time consuming...
3,384
Good Morning , I have a MicroLogix 1500 program I would like to convert to a CompactLogix 1769-L18ER. Can I use the RS Logix 5000 Tools/...
4,022
I have a s:7 status problem which is, as I could found related to the 0-7 racks of the plc (PLC 5) . However I tried to search in the GSV block...
2,986
Hi, I have a PCE instruccion error (PCE 103), due to the status file S[8] in plc5 when tralslating it to rslogix5000 . So my question is, how do I...
2,262
