Translating comments and Symbol list in Step7
Prince
Jun 2002
284
I need to translate comments and symbol list in a Step7 project from italian to English. I know both languages but it seems very time consuming
Is there a fast and automatic way to do that?
How can I export all the comments in a Block or in a project?
Which software are you using? Simatic Manager, or Portal? Which version?
Either way, there should be a way to export all texts to csv files. That way you can open them in excel and have one column for the existing Italian and one column for English.
Simatic Manager V5.5
I know a way for symbol lists but is there a way to export the comments too?
How can I import it back after translation?
Hallo Prince
the previous mail is right export the documentation
make sure your source and target language are set correct
I prefer excel
you will get several files symbol / block header / comment / ..
take each file and translate only the column of the foreign language
make sure the original language and foreign language column are
equal length
when done import the files back into the project and change language
Hi, I have a program that is mainly coded with Italian comments. I want to find a way to export all the comments and then run them through google...
1,321
Good Morning , I have a MicroLogix 1500 program I would like to convert to a CompactLogix 1769-L18ER. Can I use the RS Logix 5000 Tools/...
4,024
I have a s:7 status problem which is, as I could found related to the 0-7 racks of the plc (PLC 5) . However I tried to search in the GSV block...
2,988
Hi, I have a PCE instruccion error (PCE 103), due to the status file S[8] in plc5 when tralslating it to rslogix5000 . So my question is, how do I...
2,262
I have a siemens PLC 300 series. all of the programe from block names to the code, SCL is in german is there a way to translate this to english?:furi:
2,126
