geniusintraining
Ron Beaufort said:...just wondering ... how did you keep track of "five scans" for each of the systems? ... did you use the "single-step" method that I mentioned above? ... if not, any difference between the fixed and the modular systems might be a result of simply "miscounting" how many scans had been processed in each one of the systems ...
Ok the other Ron this time (Beaufort),
why did you ask about "five scans"?, I found the test single scan in the AD software (never used it before), when I run the program besides the first scan there would only be 2 scans 'images' ...correct?, is there a issue with my (scan)thinking?
rsdoran said:Anyone have lab equipment that is capable of checking the differences?
The other scan was inverted, beside E
