sinamics abaout step 7
yuyo
Jul 2007
México
63
Hi dears friends.
I have a sinamics team regularly has an analog input've seen in the plc and its value in DEC is 1217, if this value does not have it as I modify my program so that it works well and I do not miss the team sinamics:
L PEW 256
TAW
T DB201.DBW 40
I do not want to insult you but I do not think anyone can understand your question / statement.. Could you try to explain a bit clearer so we can help you..
sorry english
Excusame english..but what i want to say that i have a bug error in axis given to me by a sinamics...this give a analog output signal Hex 372F..that goes to the analog input plc..if this value fallows below the alarm sinamics is... how can i adjust my program to compensate this loss of value..the program is as follow:
L PEW 256
TAW
TDB201.DB201.DBW40
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
107
Hello, I use a Siemens Sinamics G120C inverter in combination with a S7-1200 cpu. I use the Main Setpoint with the Providrive option and send...
756
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
961
hi every one is t possible to power the (6SL3244-0BB12-1FA0) CU240E-2 PN unit with an external power supply 24vdc without the need of the power...
567
I have G120 with Firmware version V4.7.13. In the TIA project, I have version V4.7.10. I would like to install new firmware HSP in my project. I...
1,910
