Sinamics CU240E v4.4 question
pietervdb
Jun 2006
Ghent, Belgium
67
Hello,
I need to program a CU240E v4.4 with a PM240 power module and a BOP-2.
The client wants following DI mapping.
DI 0: Start remote, setpoint comes from AI1
DI 1: Spare
DI 2: Reset
DI 3: Feedback forced cooling
DI 4: Start local, setpoint comes from BOP-2 with the arrows
DI 5: Switch local/remote. (1 = Remote)
The forced cooling start automatically.
Now he wants to work with the following procedure.
1) If switch is on remote, and the start remote is 1 and the feedback from the forced cooling is 1, then start the drive with setpoint coming from AI1.
2) If the switch is on local, and the start local is 1 and again feedback forced cooling is 1, then start the drive with the setpoint selected on the BOP-2.
Is this possible with Simotion Starter/Scout?
I know in the expert list you have P20000 to P20399 to combine signals but is it possible to select different setpoints?
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
103
Hello, I use a Siemens Sinamics G120C inverter in combination with a S7-1200 cpu. I use the Main Setpoint with the Providrive option and send...
747
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
948
hi every one is t possible to power the (6SL3244-0BB12-1FA0) CU240E-2 PN unit with an external power supply 24vdc without the need of the power...
563
I have G120 with Firmware version V4.7.13. In the TIA project, I have version V4.7.10. I would like to install new firmware HSP in my project. I...
1,882
