Sinamics, problem to connect with Starter...
userxyz
May 2002
any
2,768
Hello,
We have a Sinamics S110. A while ago we had some troubles with drivecliq and we even needed the assitance from Siemens experts. It was the drivecliq chip that was broken. While they searched for the problem, they exchanged the CU.
Now, months later I need to change a parameter on the drive. But I cannot connect !! I can see the node and I get the alarmmessage that the device (CU305) is not compatible when connecting.
I Had DriveES with Starter v4.1+ SP3.
I now installed 4.2 + SSP Sinamics 4.4
Same problem, still uncompatible.
Any ideas what can be done to solve this issue ?
Kind regards,
Combo
I now did
I now did and it works.
Crazy that you have to update software + SSP + Conversion of the project + drive to firmware... Siemens and versions, it's a problem for life.
Thanks,
Regards,
Combo
And you updated your version here?
and picked 4.4?
The Siemens guys could have put the 4.3.x firmware in the drive
And you would have been set, but they wanted you to have the
Latest.
As you saw, its easy to update your Drive ES
But I agree, I wish it would connect with other firmware too
Masterdrives used to and a message would just pop up but it would still
Connect.
Hello I am trying to install starter software on my simatic PG but the installation does not start with error that simotion scout is not installed...
2,685
Hey guys, while this question is probably better suited to the Siemens support forums, they've been slow to correct the problem I'm having with...
2,760
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
101
Hello, I use a Siemens Sinamics G120C inverter in combination with a S7-1200 cpu. I use the Main Setpoint with the Providrive option and send...
734
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
944
