Single button Start Stop latching logic
powder78
Jul 2007
Ontario
Does anyone have a sample of logic using one button to start and the same button to stop an output. I am trying to do this in RSLogix 500 and due to the scan time, the method of programming I am trying to use isn't working. Just looking for some thoughts as I need to step back from this.
Thanks!
Yep.
to the scan time the method of programming I am trying to use isn't working
You reckon? You could slow your scan time down to 2 seconds ( if that is possible ), and then your solution may work. But then every thing else will be too slow responding.
Humuor aside, do a search for flip-flop, jk or the like. There is also another thread about 'WAS' bits, this may help also.
I0/0 . . . .B3/1. . . B3/0
----| |------|/|--------(L)
I0/0 . . . . . . . . . B3/1
B3/0 . . .O 1/0 . . . O 1/0
----| |----|/|----------(L)
. . . . . . . . . .| B3/0
. . . . . . . . . .+-----(U)
B3/0 . . . O 1/0 . . . O1/0
---| |-----| |----------(U)
This should work, When I0/0 goes on it sets B0/0 It also = B3/1 so B3/0 cannot set again while button is pressed, this sets O1/0
& resets B3/0 but cannot reset B3/0 on any futher scan as O 1/0 is on
As B3/0 is reset on set of O 1/0 this cannot reset O 1/0
If button is released B3/1 is off but on the button I 0/0 being pressed again & the last rung is true reseting O 1/0
you could use the oneshot bit in slc but I showed standard logic for this purpose
If you used mitsubishi there is an alt command that sets a bit on rising pulse then resets it again on next rising pulse
Stealing parky's ladder - only reference the input once.
|. . . . . . B3/1
B3/0 O:1/0 O:1/0
B3/0 O:1/0 |
Also, you have avoided using Latch/UnLatch instructions, and have created your own 1-shot. The way to go, some PLC's may not have
a true 1-shot.....
XIC Button CTU C5:0 10 0
XIC C5:0.acc/0 OTE Output
Works well but retains it's state I think (its a while since I used it)
a true 1-shot.....
sssshhhh... he stole the rest from me but who's keeping score..:nodi:
a true 1-shot.....
I am not so sure that Latch/Unlatch, SET/RESET, or any available instructions should not be used.
Not sure exactly what a true one-shot is, maybe someone could define it. I do understand it is more desireable to have it trigger rising edge.
That said AB has ONS or OSR, AD has PD (positive differential), Simatic S7 (maybe S5 too) offers a PD (I think an ND too), GE has POSCOIL and NEGCOIL, Simatic/TI Softshop has a one-shot that uses the # sign. Unitronics has -}P|- positive edge transition. Those are the programs I have on this desktop, my laptop has more but think all them have some form of positive edge triggered contact or coil that is only on for one scan.
S7-200 has a toggle function.
The instruction may not be called one shot, it may be differential, transition, positive edge and may be a contact or a coil.
Since we are on the subject what brand(s) do(es) not have a one shot?
May start a thread about using latch/unlatch, five years ago there is no way I liked them but things change and not sure there is no reason they should not be used.
A one shot is usually accepted as something that is high for 1 scan only. Rising or Falling edge, whichever you want (S5 never had one, so S7 has two just to be flash).
one shots and latches have their uses and are a major pain in the @rse when they are abused.
Nothing worse than the timing issues you can get when someone falls in love with one shots.
Neither, except in this application, are they really needed?
I used a small PLC (programmable relay infact) recently, and I thought that it only had a pulse instruction, but have jsut double checked, and it does have a one-shot.
One shots and latches have their uses and are a major pain in the @rse when they are abused.
I use them also, but when they are required. If I can avoid them I will, unless there is an absolute need, and there are plenty of cases in some of my projects where I use them
re:
Politly this must be the world's shortest 1 button on-off lad. code!
This is the smartest code i ever done, i used in seweral applications and newer failed or timeouted...
But it uses 17bits instead of I/O's..
Savaş; (Thx. M. Emin Dinc)
Thanks to all...
I appreciate everyones input...I knew that there were a variety of ways to do this and according to the posts, there are quite a few.
Again...thanks a bunch.
Hello everyone, been awhile since I've posted..... As the title suggests, using Crimson 3.1 software (Red Lion) I cant seem to figure out if its...
1,713
Hi, So I have one push button(non-latch momentary) and would like use it to trigger two function sequences with the short press for primary...
2,005
I've used the simple momentary switch toggle logic for a few decades now. Now I need to find logic that allows the toggling to latch/unlatch a...
26
9,865
I'm a beginner in PLC education, struck with a problem. Anyone can please help. The problem is: I have a single push button. When I press &...
30
15,207
Hello, I have a SLC5/05 and am having problems writing code for a pushbutton (momentary) to start and stop a process. The problem is this... Due...
20
16,010
