Single-module Opto-22 bases ?
Ken Roach
Apr 2002
Seattle, WA
17,482
Has anyone here on the Forum come across a relay base for Opto-22 "G4" single-channel solid-state relay modules that holds just one module ?
The smallest "rack" holds 4 modules and I have a very limited amount of mounting space.
I saw that Phoenix Contact made one but it's apparently obsolete.
I know there are plenty of other DIN-rail-mount solid state relays in the under-5-Ampere range that will work, but there's an installed base of G4 single-channel modules in this application and I'd like to keep using them, just in a narrower mounting package. I only have 2 modules to mount.
I've done some extensive searching on Google, inside Newark and Allied and Grainger catalogs without success, so I figured I'd query the PLCTalk community.
Thanks !
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
86
Does anyone know of a maker of a 'GENIUS-like' module that can supervise a wire with a small amount of voltage, measure the current, and produce a...
1,469
I am converting a SLC 500 to a Compact Logix. I plan on using a Compact Logix 5380 with conversion Kit. The problem is that the analog input cards...
151
Hello, friends, I am trying to upgrade a system that uses an Onrom incremental encoder (E6B2-CWZ6C) connected to a Danfoss VFD (FC360), but now...
276
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
