blackbird307
OP
Alright, so I tried the 30A time delay. It worked for the duration of the time, but still blew. Car moved a little, once again, but longer before blowing, by a few seconds. The motor sounded like it was having a really hard time. I don't understand.... this lift supports weights up to 8000lbs, and my car isn't half that. The motor shouldn't be drawing that much current under regular operation. I am going to see if changing motor to one of less rpm, yet same hp and see if that helps.
I would measure the current with my oscilloscope, but I don't have a current clamp with a BNC connector.
I was thinking of using one leg of a 60A 220 and connecting it to the motor. I have a plug and a bunch of wire. Would anyone here object to that? Maybe first figure out why the motor is working so hard.
CordedIf the valve did not open, the motor has to bypass all pressure. Also check voltage drop. What size wire to the list? Corded or hard wired?
+ 1 for Lic. Electrician
