Single phase motor blows fuses under load
Not sure what you mean by "gave the cables some small"
Also my load is 2/3 of the rating lift will go up from starting but nit raise from a mid point
And motor does not draw more than 40 amps as it does not trip main breaker
The hydraulic cylinder pulls cables which in turn lift the vehicle platform. By giving the cables more slack i was able to give the motor a chance to start because of initial current draw, when the load was a apllied tightened cables it didn't trip the breaker. Motor didn't sound like it was struggling. So what i think the problem may be it's that the load is too much for the motor to handle at start. A larger motor might help or maybe some sort of starter would fix my problem better
Hi
My lift is a sissor type no cables direct hydraulic the cylinders
But issue is similar to yours by friend has the same lift, He bought 3 the others work but if I had cables I am sure your suggestion would solve it
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
539
Hi PLCs.net! I'm working on a multi-motor system, most motors are single phase, driven by servo drives. I wanted to check what kind of motor...
1,534
Any panel I've built with contactors and overloads has been 3 phase. I'm now quoting on one with some small single-phase loads. Definition of...
24
5,675
Hello everyone, I ran into this 230 single phase two speed motor with two capacitors and a relay (see picture) and have a few questions: The...
1,405
